Teacher / student setup
I am a teacher in a Middle School. I want my students to follow Lesson 1.1 Jumping into Onshape.
What do I have to do ?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 930 PRO
    Lesson 1.1 of Intro to CAD introduces your students to Onshape and the interface.  They will practice navigating Onshape documents and moving models around.  Then, for the final lesson, students do a scavenger hunt.  You have two ways to do the scavenger hunt.
    1. The teacher creates a copy of the 1.1 Onshape document and shares it will all of their students with edit priviliges, using the blue Share button.  That way, every student can be in the same document at the same time, which is really fun.  You can use Team or Classroom sharing to make that easier.
    2. Use Classes & Assignments to attach the 1.1 Onshape document to an assignment.  Then, each student will get their own copy of the document to work in.
  • robert_parker992robert_parker992 Member Posts: 4
    Thank you! I'll give it a go!
