Remove Part # references when copying a document
Jed_Yeiser
Member Posts: 57 PRO
My team and I duplicate documents often to create new sizes of a design, or to create a related design. When copying a document, all part numbers from the source document are retained in the copied document and treated as a revision of the part in the source document. This means that when releasing a new design, we must first manually clear out part number references in a release candidate before generating new part numbers. I'd love to see an option to 'Clear Part Numbers' when copying a document so that the new (copied) document has 'fresh' or no Part Numbers assigned to bodies generated in Part Studios.
1
Thanks!
I can see that configurations may take more effort than they’re worth in some cases, but if you’re copying a document to create another one that sounds a lot like there might be enough commonality to warrant a configuration approach.
Design
@S1mon
To be fair, I probably need to take a deeper look at configurations. There are instances where I could see configurations working, specifically different sizes of a given construction (my team and I are the ski engineering arm of a ski company, so different sizes here would mean different sizes of skis). The challenge with this approach is being able to see documentation and data for multiple different sizes at once to compare. We will often take one 'model' (read: Onshape Document) and copy it for use in a completely different ski construction. The data for the new ski construction needs to be maintained separately and - aside from some feature tree structure - really doesn't share much in common with the source document. I've always seen configurations as 'slightly different versions of the same fundamental thing' whereas unique documents are 'fundamentally different things, even if the inherent structures are broadly similar'.
