My method of inserting symbols into drawing notes
chrisjh777
Member Posts: 209 ✭✭✭✭
I read a recent comment in the Onshape drawing discussion area, where the writer asked how another user inserted the surface finish symbol.
I thought I’d share the method I use to insert symbols, such as Greek and Mathematical, into my drawings. I have been doing this for years in Solidworks, because the standard Solidworks Symbol Library is somewhat limited.
I created a Word Document and inserted all my commonly used symbols. When I am drafting, I always keep this document open. If I need to insert a symbol, I simply switch to the open document, select and copy the symbol, then paste it into the drawing Note Text Box where I need it.
At any time, I can add to the document, any new unusual symbols. The symbol document grows with my needs.
I have attached copies of my current symbol document in .docx format. For those using Open Office, I tried to attach a copy in .odt format but was "not allowed".
Note that Notepad does not support some of the symbols, so don’t waste your time converting to a .txt format. Same for .pdf files.
I use a laptop for most of my CAD/CAM activities and, for some reason, laptop keyboards do not support, like PCs, the insertion of “Alt xxx” inputs. So I was forced to adopt this strategy.
I hope this idea is of use to others.
Sounds like I need to give this some more thought and testing in Onshape. I have only used this method in Solidworks.
I created a test Onshape drawing and tried to insert my commonly used Greek Letters and symbols into Notes such as:
Ø Ω ° π ↓ Δ ± ≤ ≥ ↑ λ μ σ √ ≠ ≡ ∑ ∫ ≈
⅓ ⅔ ⅛ ⅜ ⅝ ⅞ ¼ ½ ¾
•That which works in Solidworks does not work in Onshape Drawings :'(
Funny that they insert fine in this post.
It was a good idea. I guess we will have to wait for more progress.
%%c diameter
%%d degrees
%%p plus/minus tolerance
I have tested this on Mac OSX with Chrome, but anticipate that it should work across the board on the browser versions of Onshape.
Hi Mike,
I found these shortcuts and have been using them.
I tested all combinations of %%x with all letters of the alphabet in the hope to find other symbols that may be useful. Only the 3 that you mentioned above work.
I am curious to know the origins of the %% nomenclature.
I successfully copied an inserted all of the Greek Symbols and Fractions as a note into Sheet 3 of the drawing in this test document.
https://cad.onshape.com/documents/164261ef912d5f9d4cce106e/w/cddc1ed294517ac1da648079/e/1a6715e0a949384e09924203
