What is that for a symbol?
mohammed_hassunmohammed_hassun Member Posts: 15 EDU
What is that for a symbol next to the 1,6? What does it mean?
  • glen_dewsburyglen_dewsbury Member Posts: 1,304 PRO
    Surface finish. The allowable roughness which determines what sort of tool and process to accommodate.
    A milling cutter will typically give a rough finish while surface grinding operation can produce a much smoother finish.
