Hole feature errors when attempting multiple holes on same parts
I am making a sheet metal box with three stacked surfaces, and need several different types of fasteners on specific parts and in specific sizes/locations. I am able to get the hole feature to work smoothly one feature at a time. However, when I attempt multiple hole features on the same parts (In different locations and sizes) -- I end up with an error on at least one hole feature every time. It doesn't seem to be a problem with any specific hole feature, as I am able to recreate the problem with several combinations of hole features.
Any idea what I'm doing wrong?
File here: https://cad.onshape.com/documents/a6d53f76b9a7d3d386142987/w/ddb478679e3592b9cb74774d/e/f45290ab526126e78b6c21b9?configuration=List_KPyi1QyBUWJl3s=Copy_of_custom&renderMode=0&uiState=664b7f1a1c91665597548dd2
lana Onshape Employees Posts: 732
This is a bug. Sorry for the inconvenience. I've filed an issue.4 -
finn_colando Member Posts: 7 ✭
lana said:This is a bug. Sorry for the inconvenience. I've filed an issue.1
I have the same issue and it forms a serious bottleneck in my project. Where and how can I track the bugfix status?
Not sure if this works for everyone, but i put my rollback bar back to where it was just after the sheet metal part i needed was created, then inserted the sketch and cut the holes and drug the bar back to the bottom and so far, no issues. not convenient, but got me past the issue
