"Return to main" button disappeared
Roberto_VerduciRoberto_Verduci Member Posts: 29 ✭✭
Hi,
I don't know if is a bug or not but I can no longer see the "Return to main" button when I'm in a versioned status.
Is there an explanation? or a setting to change?
Thanks
  • Roberto_VerduciRoberto_Verduci Member Posts: 29 ✭✭
    I've noticed that not all documents behave the same way... some have the problem, others don't
  • ParitoshParitosh Member, Onshape Employees Posts: 2 image
    This is most likely a bug. Can you please report it to support?
    For now, you can access 'Main' by opening the 'Versions and History' panel on the left and clicking on 'Main'.
  • robert_stilesrobert_stiles Member Posts: 159 PRO
    + 1 on this bug. Threw me for a moment
