Drawing does not change when part is changed!?
hansrudolfhansrudolf Member Posts: 55 ✭✭
Ok, here i am again. Just discovered that a drawing is not updated when a part is changed. Generating a new drawing is easy in most cases, but not so when I have to add all the dimensions and other inserted stuff again. Is there no 'redraw' which keeps all the manually inserted data?
regards, Hansrudolf
  • hansrudolfhansrudolf Member Posts: 55 ✭✭
    Oh, sorry, forget that. I found the button  (ashamed).
    Regards, Hansrudolf
