How can I change the cutting line?
mohammed_hassun
Member Posts: 15 EDU
in Drawings
My cutting line is the left. I would like to use the cutting line from the right. But the problem is that I can't find the option to change the cutting line so that it is thick at the beginning and thick at the end and that it is basically also much thicker from the line than on my left illustration and then I would also make the arrows thicker.
