Insert image
john_beasleyjohn_beasley Member Posts: 2 EDU
When I try to insert an image, the insert panel is too large and goes off the bottom of the window and I can't get to the bottom of the panel to search foe the file. I see no way to resize the panel. i am using a Macbook Pro with Monterey OS.
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 407
    Is your browser tab zoomed?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 683 EDU
    Safari or Chrome, hit command+0.
