Fillet Tool Not Working (Working in SolidWorks)
Hello,
Hoping someone here can help me out!
I'm trying to add a .125 radius to the groove, but Onshape doesn't seem able to achieve this with the fillet command. I'm able to achieve this with the basic fillet tool inside Solidworks, so I assume Onshape should be able to do it as well. I've added the same part from Solidworks with the fillets added for reference in the part linked below.
https://longbowcs.onshape.com/documents/b40fbe7531afca9978bc043c/w/2bdd68173e63cb5413f9cafb/e/8473ae2c95d679e9a15e598f?renderMode=0&uiState=664e5ae42511002b640d79d6
Thanks,
Shawn
Thanks,
Shawn
- Try a smaller radius, and sneak up on the value. This may give you some clues where things are failing
- Turn off tangent propagation and fillet parts of it to see what works
- Use the curvature analysis tools to examine the quality of the faces and edges - there may be some crappy results from the wrap feature which are making this challenging
- Manually build the end (or whatever bit is failing)
Does the part need to be identical, or just functionally the same? What tolerances do you have to play with? Can you cheat by tweaking the size of anything?Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
Sorry for the no-public; I can't find the public share option on Onshape Enterprise.
