Hole Feature - no more blind in last?? and no more custom hole sizes
sam_wehrlisam_wehrli Member Posts: 15 PRO
Hopefully I'm missing something, because I use blind in last holes a lot. Also, I used custom hole sizes quite a bit too, I work with laser cut parts and the holes aren't always needed on nominal drill sizes.
  • GWS50GWS50 Member Posts: 498 PRO
    edited March 2024
    I was  concerned about the 'Blind in Last' too but it is there. You need to select the fit to create it...might take a bit of getting used too!
  • Benjamin_StraussBenjamin_Strauss Member Posts: 7
    Unfortunately the "tapped depth" feature is now broken with respect to this context. The system has no idea how long the tapped section is in the blind part.
