MMU 3D Print Exporting
SleepyheadSleepyhead Member Posts: 20 ✭✭
I am trying to export a design so as to 3D print in 2 different colours. However the 3mf file does not show the numbering to be imbost into print in a seperate colour.  The number printing is not proud or sunken but but the same level as the top. I have successfully achieved a small sample of the required desgn in a different program and sliced it successfully
Any Guidence.
  • SleepyheadSleepyhead Member Posts: 20 ✭✭
    Problem solved rather than using 3mf, I selected each part and exported as stl. when loading into Prusa slicer i recieved a message saying the parts appeared to be imperial and not meteric. As this was not the case i said NO after ticking the box to all objects. You may not get this message
    the next message box was
    This one I selected yes, and Bobs your uncle, After setting the colours for each part it sliced with out issue
