replace item in assembly orphans the mate connectors
kees_bijker
Member Posts: 170 ✭✭
in General
When you replace a fastener in an assembly, it orphans the old mate connectors this fastener was fixed with. When you then replicate the new replaced fastener, it always chooses the orphaned, now defunct, old mate connector.
This means you always need to go back and find the mate connectors that are orphaned, delete them one by one, before you can do a new replicate.
Would it not be more logical to delete the old mate connectors with the replaced item completely? You will always have to make a new mate connector anyway but in this instance it always finds the older broken mate connector from the deleted item.
Maybe I am doing it wrong, please enlighten me if this is the case.
sorry I forgot to mention it is implicit mate connectors you define during assembly.
