Problem with constructing a thread (for 3D-printing)
Hi all,
again one of my strange problems. I want to draw a thread in a nut, which I want then to print on my 3D-printer.
I managed to draw the nut, the helix and a plane perpendicular to the helix. Furthermore, I could also draw a triangle on that plane. But when I want to sweep it, I see it only in dashed lines (also if I use the section view) and the sweep does not work.
The strangest thing is that many months ago I could do that operation, with the difference that I used a circle instead of a triangle.
https://cad.onshape.com/documents/221a69568cae352864f9ca25/w/cde28ce27d88e56548e72d0e/e/54fbaad6bbd23af4244eab78
(hope that works)
Regards,
Hansrudolf
(hope that works)
Regards,
Hansrudolf
Do you actually want to model such fine features, though? You could either buy the nut, or leave just a hole and let the bolt make its own threads.
I'm sure your answer was well-intentioned, but doesn't help me much.
I really want to know why my approach has failed, and working with that custom feature is way above my pay level. I tried to add that to my part, but found no way, especially as I didn't find out what's the real name of that function. "Search or paste URL" needs a meaningful input, am I right?
Anyway, thanks
Hansrudolf
https://cad.onshape.com/documents/4d8a1ca8337e0cf764688ac6/w/c37405a9c9af56dca9503b66/e/0c4f1b9bebc864a534145ffa
I could now draw a part with an external thread, and print the nut part also. The nut is not perfect, the thread does not 'fade out' correctly at the end. Don't know how I could that describe better, the thread should continue about 90 deg. more (a guess could be 180 deg.)
Another internal thread failed again. I think I will use a thread tap for this one.
Maybe I find some time to study how that custom feature works.
Case closed for the moment.
Kind regards,
Hansrudolf
