angel a extruder
I'm a new beginner in onshape, and need some help to show how to change the angle of a topic. My subject is a bracket for a glass shower wall which is drawn as a T but where the foot must be angled 3 degrees. I have set aside a plane in the gr. that I want it to be angled, seen from the side.
Is there anyone who has any suggestions
In that case, there is an option in the extrusion dialog that lets you set the extrude angle, so it does not necessarily have to be perpendicular to the sketch, but rather in the direction you set. In this case, 3º
For setting the direction, a sketch line, a plane or a MateConnector will be enough.
