Circle geometry from /partstudios/d/{did}/{wvm}/{wvmid}/e/{eid}/features does not match definition
roth_vannroth_vann Member Posts: 5
According to the schema I should expect xCenter and yCenter to appear in the geometry definition but I am only seeing radius. Is there way to query the center too?
This is what I see in the entity
            "btType":"BTMSketchCurve-4",
            "geometry":{
               "btType":"BTCurveGeometryCircle-115",
               "radius":0.02504807710647583,
               "clockwise":false
            "centerId":"zVVB6lg0iq2O.center",
            "internalIds":[
            "isConstruction":false,
            "isFromSplineHandle":false,
            "isFromSplineControlPolygon":false,
            "isFromEndpointSplineHandle":false,
            "parameters":[
            "namespace":"",
            "nodeId":"MUVCHpUnkKfqVdvS2",
            "entityId":"zVVB6lg0iq2O"
  • Caden_ArmstrongCaden_Armstrong Member Posts: 348 PRO
    How are you running your API request?
    I just ran against a sample that I have, and I am seeing a different output for a circle in a sketch.
    I have an xCenter, yCenter, xDir, yDir parameters.
    if you are doing
    /api/v6/....
    try without the /v6 (or whetever api version you are calling)
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • roth_vannroth_vann Member Posts: 5
    if you are doing
    /api/v6/....
    I did some testing and this problem only occurs in /v6. It'd be simple for me to swap versions but there are some other differences in the format that makes v6 easier to use (like with geometryIds).
    I'm wondering if this issue is intended or a small bug since the rest of the schemas have been accurate so far.
    I am guessing this is a small bug, those parameters should probably be there. Bit hard to define a circle without a center...
