"Un-split" (merge?) coplanar surface made of several faces?
eric_pestyeric_pesty Member, pcbaevp Posts: 2,642 PRO
It seems like this should be simple enough but can't seem to find an easy to way to do this.
Basically I want to get rid of "splits" in a planar surface made of multiple faces.
An example would be if you use the slot tool on a chain of sketch entities and then create an offset surface from it you end up with a single surface but that is split into different faces where the different sketch regions where.
It's just one planar face so there is no "need" for these splits... What's the best way to get to a single face from here?
    I try to avoid trimming sketches unless needed. In this case trimming got rid of the extra line work in an offset face.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,642 PRO
    edited May 2024
    I'm dealing with a more "generalized" case so manually trimming sketches is not an option...
    It looks there's a way to do it in FS but it seems odd that I'd need a custom feature for this!
    <div>        opExtractSurface(context, id + "offsetFace1", {
                    "faces" : definition.face,
                    "redundancyType" : "REMOVE_ALL_REDUNDANCY"
            });<br></div>
  • _anton_anton Member, Onshape Employees Posts: 534 image
    edited May 2024
    Well, it's a hack, but you could extrude and then delete everything but the cap face. Edit: or extract the surfaces individually and then boolean them together.
    edited May 2024
    Yeah, that's one manual way of doing it and where I started...
    I ended up creating an "Unsplit" FS that does the job (and also creates a composite of the whole thing), pretty simple using  "REMOVE_ALL_REDUNDANCY" option from opExtractSurface:
    FeatureScript 2368;
    import(path : "onshape/std/common.fs", version : "2368.0");
    annotation { "Feature Type Name" : "Unsplit Faces" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            // Define the parameters of the feature type
            annotation { "Name" : "Faces", "Filter" : (EntityType.BODY&&BodyType.SHEET || EntityType.FACE) }
            definition.faces is Query;
            annotation { "Name" : "Create Composite?", "Default" : true}
            definition.composite is boolean;
            // Define the function's action
            var bodyFaces = qOwnedByBody(definition.faces, EntityType.FACE);
            var faces = qEntityFilter(definition.faces, EntityType.FACE);
                        "faces" : qUnion([bodyFaces, faces]),
                        //"tangentPropagation":true,
            try
                opDeleteBodies(context, id + "deleteBodies1", {
                            "entities" : qEntityFilter(definition.faces, EntityType.BODY)
            if (definition.composite)
                opCreateCompositePart(context, id + "compositePart1", {
                        "bodies" : qCreatedBy(id + "offsetFace1", EntityType.BODY),
                        "closed" : true
    I also created and IR to add this to the standard offset surface:
    https://forum.onshape.com/discussion/24214/add-option-to-merge-un-split-faces-in-offset-face#latest
  • S1monS1mon Member Posts: 4,095 PRO
    Interesting. Plasticity (also Parasolid based) has a command to "Delete Redundant Topology". It will remove any splits from faces which could be the same face, including curved faces. I wonder if there is the equivalent low level tool in FeatureScript? I found options in opMoveFace and opOffsetFace.
    Interestingly, the opMoveFace wasn't helping in this case...
    The code above does work on curved faces, it doesn't work on solids directly (I wasn't trying for that...) but if it can create a single face from selecting split faces of the solid and then you can do a "Replace face". Not really needed as a "Delete face" with "heal" normally does the job (but not on a surface).
