Math operators don't work as expected.
RagwingRagwing Member Posts: 6 ✭✭
edited June 2024 in Community Support
Why does addition work but multiplication not?
Gotta be something simple...
Thanks,
  • S1monS1mon Member Posts: 3,746 PRO
    They are working correctly. A and B are values with units. A*B would equal 12 in^2, which isn’t a length. You can either divide by “in” or use the “any” category, depending on your goals.
  • romeograhamromeograham Member, csevp Posts: 725 PRO
    edited June 2024
    I think it is because the result of multiplication gives an Area unit (in^2), not a Length unit. See if it works if you change the type to "Any" rather than "Length".
  • RagwingRagwing Member Posts: 6 ✭✭
    Thank you! That pointed me in the right direction. Just learning about OS arithmetic. In my application, one of the variables is actually dimensionless. Changing to "any" resulted in the correct outcome.
    Much appreciated!
    If the variable is dimensionless, but it’s a real number (maybe a quantity or ratio), you should use the “number” option. “Any” is for any type which can’t fit in the first three choices.
