I am trying to add a fastened mate to a ring. however the mate always goes to the center
chris_notforpublication
Member Posts: 9 ✭
I am modelling a gas stove trivet. It has an iron outer ring and four supports. The supports are evenly placed around the outer ring. They are welded into place so there is no feature on the ring to attach a mate to.
The problem is every time I try to add a mate to the ring it snaps to the center of the ring. The only way to move it to the outer edge of the ring is to add an offset.
This means if I vary the size of the ring the mate will no longer match and I'll have to come back in and adjust it. While this is of course entirely doable it seems I am missing something and no amount of searching has revealed a solution.
How do I get a fastened mate connector to attach to the outside of the ring (circle)?
_anton
Member, Onshape Employees Posts: 501
As always, there's a number of approaches, but here's one: https://cad.onshape.com/documents/29623ad9a9f974579cb6a278/w/661cb404012748e4088488fc/e/bbcf3ac79be8205f1bbd9143
(Explanation: I made the ring a revolved body, and put a mate connector on the sketch, owned by the body. Now the assembly will have a mate connector to use.)0 -
_anton
I think the Variable Studio approach is the best, just slightly more advanced. Not only because it solves this issue, but because it lets you drive the entire design from one place.1
A simpler and better approach for something like this is to just draw both parts in the same part studio, with the support drawn in its correct location directly, you can then just use a group mate in the assembly.
Another benefit is you would then be able to set the gap between the supports in your design directly independently of the ring size.
Edit: like this: https://cad.onshape.com/documents/bb87cd19f683250c0c05e3b5/w/84e8c07110a7c80e838ac81e/e/806de1ad4e5baad34e289051?renderMode=0&tangentEdgeStyle=1&uiState=6660a30933840c470773debb
This is the one I went with.
