How can I set the language settings for the Forum Pages?
Hi folks,
I live in Germany but I want to have all the forum pages to be completely in english, otherwise it is a mess. Half of the menus are englisch, posts are english, but some page elements are translated. In Onshape (CAD) it is easy to set the language, but it has no effect on the forum pages. I have not found anything in my account settings to manage this.
I add a Screenshot... yellow=German, green=english
Some advises?
eugenia_c Member, Channel partner Posts: 1 EDU
At the bottom of any page on the forum, you can see the available languages to set the forum locale separately from your Onshape settings. Maybe you have selected Deutsch, which is causing these issues. If you reselect English, everything should return to English.
2 -
rafael_telgmann Member Posts: 137 ✭✭✭
@eugenia_c
This is exactly what I was looking for! Thank you so much!0 -
Eugenia_Camacho Member Posts: 2 ✭
If you scroll all the way to the bottom of any page in the forum, you will see the languages available to set the forum locale separate from your Onshape settings. You may have selected Deutsch, which is causing these issues to occur. If you reselect English, everything should return back to English.
No need to apologize. I really appreciate the active community here and the help from all of you. I found the solution in a few hours, which is great!
