Exporting multiple parts as a single part. As part of a complex model
george_sugar
Member Posts: 6 ✭
I'm hoping there is a better way to do then manually ..
I am looking for a way to export a design in to a single zip file but I have several parts I don't want exported individually but be part of another Items. Example Part a,b.c should really be a single part but because they don't physically touch can't be merged. Manually I can export and add it to a zip file. But is there away to customize export or instruct onshape to export part a,b,c as one part and export the rest as individual parts?
I have a situation where I have several (print) support structures part of the model. physically don't make contact with the main part/item. Is there away to export the a part with it's support structures as one part and still export other parts of the model as individual parts with in a zip?
_anton
Member, Onshape Employees Posts: 523
You can use the composite part feature, and export the composite parts.0
