Offset Tool Error
Lewis_MainaLewis_Maina Member Posts: 12 ✭✭
In sketch mode, when I try to offset surface edges (sketch too)internally tool fails but doesn't fail when I try to offset outwards. What could cause this to happen?
External offset:
Internal Offset:
fails even when I try a smaller offset  value
Onshape Link:
https://cad.onshape.com/documents/28a5b6e55afe05d772c94b15/w/fb696885662023439a458dfe/e/2f36b8aa1ff2cfa4c5d52bd3?renderMode=0&uiState=666627053180d073bd72c3f0
  • S1monS1mon Member Posts: 3,773 PRO
    The offset tool in the sketcher is very finicky. Sometimes it can be more robust to extrude the outline as a surface, and then offset that with the surface offset tool.
