How to link faces together
Im having trouble with these faces on my sketch, i wish to conjoin them, merge them all into one strip, basically remove all the lines in between, and make it all one face.
    @landon_villanueva, one approach is to change the display setting rather than doing anything to your part and surface models.  There is a drop down menu right below the "view cube".
  • landon_villanuevalandon_villanueva Member Posts: 4 EDU
    @matthew_stacyIt's smooth now, but hovering my cursor over the piece, it still shows it as 5 different strips
  • braxton_kennedybraxton_kennedy Member Posts: 3 EDU
    Ever find a solution?
  • martin_kopplowmartin_kopplow Member Posts: 1,279 PRO
    It is probably not about removing the lines, it is about creating a face that replaces all those faces now seperated by lines. That would propably best be done within the sketch before extruding. The same goes for tangency.
    If the current faces were tangent to each other, a display setting not to show tangent lines would at least do the job for visual representation. Remove the checkmark:
