Configure Text Flipping
Jonathan_Hutchinson
Member Posts: 151 PRO
in General
Could it be possible to configure the flip horizontal/vertical options? Use case is for L/R versions of something, so the extrusion is projected one way or another.
As a workaround you could put the sketch containing the text on a mate connector and flip the mate connector. Or maybe use one of the "text" feature like "surface text" that lets you use a variable:
https://cad.onshape.com/documents/cfec40e2b66bb4ddb2f3414b/v/3f1bcca2812d650a51c9960d/e/7a70ac021729253c4df9d213
