How can I only fillet the edge between these two intersecting holes?
Hi guys, hope you're all well. I am pretty much brand new to CAD and after watching a bunch of tutorials I have started to create some parts to print in my 3D printer.
Cheers guys.
I have been playing around with creating a tool holder for my bench and have run into an issue that I can't seem to google my way out of.
I have two intersecting holes that I have created with remove extrusions in order to slot some allen keys in, when trying to fillet the edge between the two, it appears to also fillet the top layer edge as seen on the left picture. Is there another function I can use to create only the fillet that isn't highlighted? Or am I going about this the wrong way using extrusions.
Here is a link to the mentioned file; https://cad.onshape.com/documents/dc30d83daba3f937d606f607/w/e6e0d9bc8b445909300dbab0/e/a3f0e94da1b903d50e7fc7d7.
Cheers guys.
rafael_telgmann Member Posts: 137 ✭✭✭
Hi, you'll need to use a variable fillet with a radius of zero on the vertices.
Take a look at the last feature to see what I mean.
https://cad.onshape.com/documents/0cabc7ccdc899e107ef41004/w/f62a44c2a1f166d780cce585/e/a04e76c1d6bb14d7b21baf4c?renderMode=0&tangentEdgeStyle=1&uiState=666df667bf9efc1d9082fe2d
1
