Creating text on a concave surface
I'm attempting to inscribe the word Kitty in a concave surface. I first attempt to define an intersection line with the Plane that bisects the surface and it appears to be from top edge to top edge passing through the low point of the spherical section. When I choose surface text I cannot seem to select the baseline I created with the intersection option but rather only half from top edge to lower center and the text shows up on one side or the other of the midpoint. It seems it wants to use the arc I used to revolve the 'bowl' in the first place. I've searched for surface text on a concave surface in help, on google and YouTube. I've reviewed lots of videos about text on the outside of a sphere or ring but none that provide the epiphany of putting text where I want it in a hollowed out bowl.
I would either like to center the word 'Kitty' in the bottom of the circle or as an advanced idea, pick somewhere else on the surface and have the text go there. I'm failing at all attempts.
Thanks in advance for suggestions.
matthew_stacy Member Posts: 489 PRO
@harry_blanek does this model accomplish the result that you are shooting for?I changed your baseline sketch ("kitty intersection") with a single line segment, centered on the cavity. That centering can be leveraged in the subsequent Surface Text feature. Also note that made the sketch is now placed on a mate connector, aligned vertically, and tangent to that same cavity. Also consider constraining (fully defining with dimensions and/or geometric constraints) your sketches. Blue sketch elements indicate that there are remaining degrees of freedom to control.Then in the Surface Text feature select the "centered" and "middle" options for text alignment.0 -
jnewth_onshape Member, Onshape Employees Posts: 89
@harry_blanek
You have encountered a sort of funny bug in Onshape. The short version is that parasolid describes every location on a sphere's surface with two coordinates. At the very bottom of the basin (the way you drew it) that point is well-defined, but the vectors that describe a tangent face's orientation there are not, so custom features that rely on that tangent face tend to dislike it. I've filed a bug.
In terms of fixes: I ended up just drawing your circular cutout profile oriented differently, and then used "Text path" (which does more or less the same stuff as Surface Text just in slightly different fashion). That moves the "pole" of the sphere away from that center point where you want to write some letters. Then it just works:
https://cad.onshape.com/documents/a1d4e1449a8c1af825345612/w/8c4b39db4b1fc7db2d031b97/e/328840af6461aeae739db432
If you are interested you can read about "Text path" here: https://forum.onshape.com/discussion/comment/101716#Comment_101716
1
https://cad.onshape.com/documents/c9f1ab6ffc9d4121e0661439/w/ab77db8baf0c7b9f4eb65dd0/e/7667d31524c5eca33e5619c3
