loft not working with guides ;-;
eitan_goldshtrom
Member Posts: 6 ✭✭
https://cad.onshape.com/documents/4415e93291eabbf9ee253eec/w/27d3564434c2b91b92bfdf5b/e/51a511cfa043954a4e85962d
i am working on a keyboard frame and need to perform a complex loft. in this previous discussion thread i asked how to fix the connections in my loft, and got the answer i needed. however, i wanted to try and find a way to remove some of the manual shenanigans involved, so decided to try building a feature to line everything up for me. i eventually got things mostly working, as seen here:
however, the curvature is wrong, which i created guides to help with. i know i don't strictly need guides for this, but it gives me an amount of control i want over the precise curve. unfortunately, it will not generate when i include the guides. here you can see the guides in debug red, and you see that the loft didn't generate:
i have tried using opLoft as:
opLoft(context, id + "loft1", {
"bodyType" : ToolBodyType.SOLID,
"profileSubqueries" : [definition.startProfiles, definition.endFace],
"connections" : connections,
"guideSubqueries" : evaluateQuery(context, qCreatedBy(id + "bridge1", EntityType.EDGE)),
"derivativeInfo" : [
{ "profileIndex" : 0, "matchCurvature" : false, "forGuide": false, "adjacentFaces" : qSubtraction(qAdjacent(definition.startProfiles, AdjacencyType.VERTEX, EntityType.FACE), definition.startProfiles) },
{ "profileIndex" : 1, "matchCurvature" : false, "forGuide": false, "adjacentFaces" : qSubtraction(qAdjacent(definition.endFace, AdjacencyType.EDGE, EntityType.FACE), definition.endFace) },
});and using loft, when opLoft didn't work:
loft(context, id + "loft1", {
"bodyType" : ExtendedToolBodyType.SOLID,
"sheetProfilesArray" : [
{ "sheetProfileEntities" : definition.startProfiles },
{ "sheetProfileEntities" : definition.endFace },
"startCondition" : LoftEndDerivativeType.MATCH_TANGENT,
"adjacentFacesStart" : qSubtraction(qAdjacent(definition.startProfiles, AdjacencyType.VERTEX, EntityType.FACE), definition.startProfiles),
"startMagnitude" : 1,
"endCondition" : LoftEndDerivativeType.MATCH_TANGENT,
"adjacentFacesEnd" : qSubtraction(qAdjacent(definition.endFace, AdjacencyType.EDGE, EntityType.FACE), definition.endFace),
"endMagnitude" : 1,
"addGuides" : true,
"guidesArray" : guides,
"matchConnections" : true,
});opLoft results in the error "LOFT_START_OR_END_CONDITIONS_WITH_GUIDES_FAILED", while loft results in the error "LOFT_NO_FACE_FOR_GUIDE_CLAMP". since i only have access to the loft code, i can't figure out what opLoft doesn't like. but i also could not get things set up for loft to stop complaining about that >:T.
eitan_goldshtrom
Member Posts: 6 ✭✭
false alarm. turns out this isn't an issue with featurescript, but with my guides.
i did some more digging and discovered that this doesn't even work with a manual loft feature (no scripting) because of some of the guides. when i remove those guides from my feature script, it works >_<. i had neglected to sufficiently test the manual approach, because of some initial manual success with the guides. but this only appeared when many guides were included simultaneously.0
