Can the endpoints of a spline be constrained to a specific angle?
julian_goodman
Member Posts: 4 ✭
I want to create a slot from a spline with the endpoints at specific angles. I can accomplish this by adding angled lines close to the endpoints of the spline and create slots for them too and have those slots overlap the slot for the spline but that seems so clumsy. Is there any way to constrain the end point angles of the spline so I wouldn't need to add the angles lines and their slots?
john_lopez363
Member Posts: 140 ✭✭✭
@julian_goodman
Julian... you cannot add "Angular" dimensions to the spline control point...BUT you can add an angular dimension between the leg of the control point and other sketch geometry.
https://cad.onshape.com/documents/feeafb87e93684b0f10c813b/w/ceb86e65fb96e6e9065eea91/e/0a7838f6fc6f0ac4a89c95f7Julian... you cannot add "Angular" dimensions to the spline control point...BUT you can add an angular dimension between the leg of the control point and other sketch geometry.
