How to "reapply" a Text Expression with a Linear Transform
Document I'm working on: https://cad.onshape.com/documents/a7ab04be3848123351993a93/v/15a53cefe34ac622a2433858/e/847b837a1d79ba5871584f37
I'm making radius gauges (for determining real world fillets). I know they already exist, but it's nice to get some more exercise.
I use a linear pattern and a variable to change the radius from 1mm to 10mm. I also imprint the size with text that is defined by an expression (in the size label sketch). It looks like the text expression is not recalculated, but the radii are.
Am I doing something wrong? Is this a bug?
_anton Member, Onshape Employees Posts: 444
It does look like you've hit a bug. I've filed an issue on this, sorry for the inconvenience. In the meantime, I think you could work around this with a custom feature: https://forum.onshape.com/discussion/comment/1017160
That custom feature didn't work for me. I had to modify it to work around this bug. It almost seems like there is some caching going on using the 2 lowest levels of the ID instead of the full ID. The work around I added was to stringify the full id and append it to the sketch id.
Here is the above example https://cad.onshape.com/documents/5ce135555b1a915d915c589f/v/c4fa827aa2cb61252fd257f5/e/a0d92078cbcd7e75eb2c59b5
Here is the fork of the Text feature with the work around.
https://cad.onshape.com/documents/3888fd8b00af2e7b4103f42d/w/34f2e031648e6cd11429949b/e/e082d95810228972b5aa9199
Hrmm, shouldn't be needed. Didn't dig, though. @jnewth
Thanks for the flag @_anton I'll take a look. Something funny.
