Help a beginner create a tapered spiral tree
mark_blasco
Member Posts: 4 ✭
I'm trying to create a christmas decoration of a tree that tapers towards the top, and also spirals.
I can make it tapered with the pattern I want using the loft tool, but can't figure out how to make it spiral.
I've been able to also make a version of the tree that spirals (using a helix on a cone shape), but the circles that run along the helix don't taper towards the top, so I end up with a big circle at the top, and the pattern disappears as it moves upwards.
Ideally I'd like to get the circular pattern to go up the helix, but taper to a point at the top, so that the pattern remains strong along the whole distance, and ends in a point. I'm unsure as to how to do this, and would appreciate any advice. Onshape is new to me, and it's likely I'm just missing something simple, but I don't understand how everything works to know what tools I should be looking for. Thanks!
MichaelPascoe
Member Posts: 2,689 PRO
Nice work so far!
Here is a similar approach you could take:- Create a cone.
- Create a helix.
- Loft a profile from the base to the tip of the helix using the helix as the path.
- Circular pattern remove or add the lofted helix.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
- Create a cone.
- Create a helix.
https://cad.onshape.com/documents/05f07b075c44fbd722dad367/w/39e7c48c5d7f8d18a7cc84c3/e/ef2e0d7672cfebb307e53ca2Learn more about the Gospel of Christ ( Here )
