Export DXF for CNC
To create a file for CNC cutting (In my present software) I usually create a blank drawing with the view of the part that I require for export. When there is a recess or pocket in the design I often draw over the top of the drawing view to create an extended area of the pocket or recess and/or offset the outer edge of the part outline. This is often because of tool radius needs to extend outside the outline of the object to get a 'clean' (non-radius corners) recessed area.
Is there a way of drawing over a view in a drawing to add these areas? At the moment there is only a line tool, more drawing tools would be useful and the ability to offset the outline of the view would be helpful?
I hope this makes sense, any help is gratefully received.
cody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 220
One thing you may consider is using a sketch in a part studio for these purposes. Any sketch can be exported to a DXF by right clicking it in the feature list.
5
For example if I want to extract the profile of a shape before milling, I can create a sketch, "use" the edges on it and then export the DXF. Sadly, when imported in Inkscape, the shape won't be one continuous closed path, but a bunch of disconnected line segments, even if you were careful to "use" a surface and not an edge in your sketch. I couldn't find any easy way to re-connect the fragments of lines in Inkscape.
That's a shame, because I was really thinking about extracting both 3D and 2.5D milling data from Onshape.
https://forum.onshape.com/discussion/1547/line-ends-not-connected-at-dxf-import#latest
If you find that after importing the DXF back into Onshape, that it still has unexplainable disconnected line segments, please consider using the feedback tool to submit a ticket.
