how to create a spiral hemisphere with the same distance
Hello everyone,
I would like to create a spiral hemisphere with opposing spirals as shown in the picture. However, the special requirement is that the distance between the two spirals or between the revolutions should always be the same.
When I create a spiral with the Helix tool, the distance on the planar plane is always the same. As soon as I project it onto the hemisphere, it is logically no longer always the same. (as can be seen in the picture).
Is there a feature or a workaround that I don't know that can solve this?
https://cad.onshape.com/documents/45dba9a13797ddb80d90e967/w/448939e33b89713aacf14704/e/9090cba823a3cded292c81c8
Thanks for any help.
_anton Member, Onshape Employees Posts: 461
Really easy with Parametric Curve, see Parametric Curve 4 in https://cad.onshape.com/documents/578ff8b3e4b0e65410fcfda3/v/69f7db3196182c708f8e4835/e/46b903b8bff0b36927baa2a6
You just need the polar angle (phi in the custom feature's convention) to be linear with the input parameter.0
