I need help how to fill up a space in a step file .
richard_conen
Member Posts: 6 ✭
in Drawings
Hello,
I have a step file downloaded from printables and imported it in oneshape.
https://cad.onshape.com/documents/826a126dbe9e8613ca44c134/w/b94a57fbf780ef71657984e6/e/08b6c1b9589fe075e48d5ffe?renderMode=0&uiState=667598f395d23821c532e8a1
I'm trying to fil up the big hole bolow to make room on the inside of the part. I tried a lot to do this but i don't know the right steps to do this.
can somebody help me ,or do one side so i can do the same for the other side? i'm trying to learn to edit files.
thanks for the help
thanks for the help
https://cad.onshape.com/documents/e27262377b81a9c076de6881/v/88d7ee6a95ee12c3e7824b79/e/23b8afb5aa98cedd61d77766
To get it perfect would require a lot more work. You'd have to recreate the tangent edges of the rounds with new curves, then turn those curves into surfaces. Unless there is another way I'm not seeing (very possible!).
Thank you for the help, verry much appericiated. ( sorry for my english, I speak dutch )
Greetings
