How to smooth a sweep transition?
w_s856
Member Posts: 59 ✭
Context: https://cad.onshape.com/documents/934a4c87b18835736d4ebebe/w/35f12551467ef51350f01893/e/3d9e67d60dc285be3e4fd06a?renderMode=0&uiState=66794ed301c11123e08f2a09
I want the transition between the main arc and the hooks to be smoother. Is there a specific way to achieve that, or is the way I built the object incorrect ("too sharp at junctions" kind of problem?)
Note: day 2865 of hoping to be taken out of the "need to moderate" category
Thank you. If I understood your image correctly, that would be to stop the big arc and the hook earlier, and insert a small arc, tangent both to the big one and to the hook. Your solution looks neat - I will try that.
