How to create a 'rabbit' or 'rebate' where two shells fit together?
ben_terry323
Member Posts: 6 ✭
I'm modelling half of a shell that I plan to 3D print twice and then fix together, back-to-back. Where the two halves meet, I want a couple of mm or so of one half to fit inside the other. In other words, I want to create a 'rabbit' or 'rebate' on the outside edge of one shell, and on the inside edge of the other. How do I do this?
Matt_Shields
Member, Onshape Employees Posts: 846 PRO
One solution would be:- sketch
- use
- extrude surface
- thicken add
- boolean subtract
https://cad.onshape.com/documents/b9ee996578adf250836cf5a9/w/1eefd1de5a773227019fd320/e/daf16ba92d946e556687eb81
0 - sketch
https://cad.onshape.com/help/Content/splitpart.htm
