wrapping a hole around a fillet
terry_milamterry_milam Member Posts: 9
I created the drawing below of a piece of trim but I don't know how to make the two groves and the side fillet wrap around the fillet at the end of the part? Anyone have ideas?
Thanks
  • terry_milamterry_milam Member Posts: 9
    anton, I appreciate you taking time to make this example but I'm a fairly novice user and I don't understand what you did in sketch 2, it looks like you created a new plane but yet it is not.  I recreated my sketch 1 and extrusion for the part I need like the example you made ( I created the curved ends in the sketch rather than a fillet) but ran into a dead end after that. https://cad.onshape.com/documents/694be3441647149a363faf97/w/0d8897ae8c6e3990d213d479/e/c17fa1fb7f2b026bf51f481c
  • robert_scott_jr_robert_scott_jr_ Member Posts: 561 ✭✭✭
    Hello Terry. Other than a plane or a flat surface, sketches can also be created on a mate connector which is what Anton has done. Select the Sketch tool and within that dialog there is an option to select a mate connector to draw the sketch on. Clicking on the smaller mate connector icon will bring up a dialog to enable configuring that mate connector.
    Alternatively, an Offset Plane could be created that is offset from the front plane.
    - Scotty
  • rick_randallrick_randall Member Posts: 389 ✭✭✭
    edited June 2024
    @terry_milam You might take a look at this -
    Of course dimensions will be wrong but process might be what you want.  Good luck
  • _anton_anton Member, Onshape Employees Posts: 428
    Thanks for explaining, @robert_scott_jr_ :smiley:
    "Implicit mate connector" is the term for this. They're extremely versatile and useful in many contexts. A mate connector is just a coordinate system; the sketch is created on its XY plane. I often don't even reference the base planes - just make a base sketch on the origin and reference everything else off that.
    Robert, Thank you for that explanation, it did help me create a sketch as Anton had drawn but now I'm stuck again.  I can't get points or lines to snap to the drawing on the sketch plane.  I hate to impose on others concerning my inexperience, is there an onshape tutorial (or something on youtube) that would explain how to create a grove that wraps around a part?  Thanks again  Terry
    I'm baffled
    Terry, try the Use tool to capture the elements of another sketch that you want to 'use'. I think that's what you're after. - Scotty
