New sketch will not revolve around the central axis
jp_lft
Member Posts: 5 ✭
I'm a total beginner, I'm trying to revolve a sketch but it either warns me that it's self-intersecting when I'm trying a full revolve, or it just disappears when I try a partial, one direction revolve, what am I missing ? (the sketch extrudes fine when I try, but won't revolve)
Document : https://cad.onshape.com/documents/c53d887effac3b5ba2ed0c6c/w/3883bb8a66f35a7a79c534fb/e/4c948b67005f9a655a43aed7
Thanks in advance
Thanks in advance
S1mon
Member Posts: 4,061 PRO
Your sketch1 seems to from your imported DXF. It's closed, but there are probably microscopic issues from the translation. You don't have any constraints so the entities may look like they are coincident at each end point, but Onshape may not internally see it that way.A bunch of the curves are very close to arcs, but are showing up as splines. I made some assumptions and redrew the sketch replacing some of the curves with arcs and removing the very small fillet, and the revolve works just fine. I added the small fillet after. It's not clear if I needed to do that, but based on experience it seemed like a good idea.
https://cad.onshape.com/documents/65c4dbbbf26325f7584108fa/w/d9c68e0e8d9816c119837a0d/e/94aa7123eda5d81421c21b37
2
I'm really liking Onshape so far but for more complex sketches I don't see myself redrawing everything every time.
Revolves, sweeps, lofts may be more difficult, depending on the details.
