Tool Libraries
wayne_sauder
Member, csevp Posts: 632 PRO
in CAM Studio
I wonder if anyone can shed any light on the plans for tool libraries. I find managing the current arrangement clunky.
From discussions, I know that more is planned, but I'm wondering if anyone can say when or what.
Does someone have an example of an excellent way to manage what has been implemented thus far?
There is a lot of work being done by our core development team right now and that will set the groundwork for our CAM developers to overhaul the tool libraries.
There is really two table needs. The first is to define the tooling and the list of end mills, etc, I have for working with but not where I'm going to mount it in the tool changer. This table I generally populate with every tool I own.
Then, there's the tool changer config table for a job, which tells us which tool number gets loaded for each tool. Then, finally, the operations, which just need to specify the tool number used for the op, which it then gets all the information from the tool changer back to the master tool specifications.
Multiple standard speeds and feeds vs. material should be specified with the tool, whereas the selection of which of the pre-defined values should be specified in the specific operation. So, for example, I would like to define Aluminum-Profiling (arbitrary name I make up) as one of the table entries for a given end-mill, which has speeds and feeds, and maybe ramp speeds for cutting, or also have Steel-boring set of feeds and speeds.
So when I working on a tool op, I specify which tool number in the tool changer I'm using, and then from that tool, specify which pre-defined speeds and feeds I want to use.
But this is mostly high level UI issues, to foundational core features which is obviously your current focus. But if for example you don't have both a tool table, and a tool-chamgeer table in your core concepts, you won't be able to build the sort of UI I would love to use.
Just food for thought...
Another thought on bringing in new tools: What about connecting to something like Machiningcloud? I do not use Machiningcloud professionally because I cannot justify it at the moment, but I thought the bit I played around with it had some real potential.
@wayne_sauder Absolutely. We plan to allow users to bring in tools from vendors once tool libraries are refined.
