Planes
in Drawings
Hi,
Please help. I'm lost. I am modelling a bike wheel. I have modelled the rim and the hub. I am now trying to model the spokes. From the sketch below you can see that I have created a set of construction lines based on the spoke centres. These lines are from the centre of the hub to the centre of the rim. I am now trying to create the spoke that runs from the top of the hub to the centre of the rim (as in the red dashed line). The spoke is to run from the outside of the upper surface of the hub to the rim. I have tried to create a new plane to line up with the line that the spoke would take but I cannot. When I try to create a new plane it will not select the points on the hub where the construction lines meet it. What am I doing wrong?
