Why Doesn't My Part Display in Assembly
Kyler_Walker
Member Posts: 208 PRO
I have a sheet metal part that I have inserted into an assembly. Occasionally, this part fails to display in the assembly. It part still shows up in the list of instances in the assembly, but I can't see it. The part is not hidden. Sometimes, it seems like refreshing the browser tab causes the part to show up, but it often doesn't. Does anyone know why this is happening if there is anything I can do about it? Thanks!
Is there any reason use the "Finish sheet metal model" feature on parts that only require sheet metal features?
