define a sketch - beginner help
rlbrk
Member Posts: 31 ✭
I'm pretty new to Onshape. I tried to define the sketch of those curves. after a lot of adjustments and play with it, that I did not understand what I'm doing, I got it constraint.
I would be happy to see how would you define it without hundred of dimensions and constraints. here is a link to the undefined sketch - https://cad.onshape.com/documents/8e52018553fc0c1015216bfa/w/03ccce68d1c39bc2c12859a2/e/2c957f722c7c1e9a16172701?renderMode=0&uiState=6686e3810a5d7b445eda0493
thanks
thanks
https://cad.onshape.com/documents/034bb6f45fa66480323240d2/w/2959e44e25e15c1af9bce6a9/e/14c61cf250cfaef0ccfee603
So the main fixes here is to move the sketch to the vertex point and define the spline by the handle lines?
I really couldn't figure out how to define this spline shape...
