Importing scanned plans
frank_ring
Member Posts: 44 ✭✭
After several hours of trial and error, I am approaching you in the hope of receiving a "best practice".
Using a professional drum scanner from a copy service, I have several large construction plans that
I would like to use as a template in Onshape.
When converting to DXF, 1 MB PDF results in 80 MB DXF!!! This is probably due to the fact that every speck of dust
is converted into a vector graphic via the scan. In addition, Onshape refuses to import this huge
DXF file (despite following Neil Cooke's instructions).
My attempt to import the PDF plan as a JPG did not work optimally either, as Onshape only displays the imported graphic
as a black field if the resolution is too high (over 150 DPI) - all quite frustrating.
I would be happy to get a tried and tested workflow from you - thank you very much
Frank
Frank
The black field thing is weird. That sounds like a bug that should be reported, but in the mean time, perhaps you could break a larger scan into multiple tiled images and add each one as a separate sketch.
