How to I set the label for each new variable in feature script
daniel_cravens
Member Posts: 29 ✭
Two related questions.
1. I would like to change the label for each new joint from #?:? how do I do that?
2. I would like to change the button title from "new variable" to "new joint", how would I do that?
Full code below.
annotation { "Feature Type Name" : "uiDoveTailSketch", "Editing Logic Function" : "onFeatureChange" }
export const CreateDoveTail = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "edge for split", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }
definition.edge is Query;
annotation { "Name" : "Base" }
isLength(definition.tBase, LENGTH_BOUNDS);
annotation { "Name" : "Height"}
isLength(definition.tHeight, LENGTH_BOUNDS);
annotation { "Name" : "Flair Angle"}
isAngle(definition.tAngle, ANGLE_360_BOUNDS);
annotation { "Name" : "Joints", "Item name" : "Variable", "Item label template" : "###name : #value" }
definition.joints is array;
for (var variable in definition.joints)
annotation { "Name" : "Offset"}
isAnything(variable.vOffset);
annotation { "Name" : "Depth" }
isAnything(variable.vDepth);
annotation { "Name" : "Flip" }
definition.flipped is boolean;
opDoveTailSketch(context, id, definition);
export function onFeatureChange(context is Context, id is Id, oldDefinition is map, definition is map,
isCreating is boolean, specifiedParameters is map, hiddenBodies is Query) returns map
println("OnFeatureChange");
if(size(definition.joints) == 0)
definition.tHeight = .01 * meter;
definition.tAngle = 65 * degree;
else
if (size(oldDefinition.joints) < size(definition.joints) && size(definition.joints) > 1)
println("Adding joint");
definition.joints[size(definition.joints)-1] = definition.joints[size(definition.joints)-2];
return definition;
- "Item name" is what you will see in the "Add X" button in the UI. So change this from Variable to Joint.
- "Item label template" is how each item is named. Doing "#parametername" will set the value to the value of that parameter. So if you want it set to the offset, you would do "#vOffset"
