Can't seem to transform a text object
frank_paynter
Member Posts: 31 ✭
I have a very simple document (here) - a simple shape and a text label. I want to resize the text label, but I can't seem to do it. I found several sites that say I should be able to use the transform tool to do this; select transform, select the text object, then resize as appropriate. Unfortunately, I can't seem to select the text entity no matter what I do. Am I missing something?
TIA,
Frank
TIA,
Frank
Also your first sketch of the main shape is also not constrained, and is blue in some areas.
Get the transform scale out of your thought process, it's not for this scenario. Improve your constraints and dimensions, and then simply type in a new text box width (or height) to get bigger or smaller text.
You would be well served going through some of the courses built into the onshape education center (free).
