Support fins for a rod mounting bracket
ArkelicArkelic Member Posts: 9
Hello everyone, hoping to figure out the best course of action here to add some fins to a bracket that will support a steel rod. I am trying to get from this:
To something like this:
Any help or guidance on what tool to use would be appreciated!
  • martin_kopplowmartin_kopplow Member Posts: 796 PRO
    Make one rib, then pattern along a curve, whith 'keep orientation' option checked.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 582 ✭✭✭
    Would a fillet suffice? - Scotty
  • john_lopez363john_lopez363 Member Posts: 123 ✭✭✭
    edited July 2024
    A couple of sketches... and a couple of extrudes...and a Boolean Join at the end.
  • ArkelicArkelic Member Posts: 9
    Thank you everyone for all the tips! Ended up going with martin_kopplow's solution
