Mystery geometry
Here is some background information first on the origin of the sketch in question. I found an STL file that I wanted to tweak a bit. I split the part using a plane and created a sketch of the resulting profile with the "Use" command. That created a "curve", but it does not seem to be either spline nor bezier. My question is what kind of entity this is. This is the document with just a single sketch in it: https://cad.onshape.com/documents/294e109e59cb7c0832e5fe9d/w/2aa7362dda57360daad0d84a/e/52ede2a468f535e038631fa5
martin_kopplow Member Posts: 756 PRO
Looks like it is a mesh face rather than a curve. It appears to be made up of small line segments. Is has no curvature ..
GregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 300
The sketch curve in the link ^^^ is in fact a spline. It happens to have an extreme number (1639) of control points, so I suspect it will not be particularly useful or clean as you would like. However ,it would be easy to recreate it with a few parallel lines and a bunch of fillets. But then again it all depends on what you want to do with it after??1
