Taper frames
graham_lock
Member Posts: 249 PRO
Hi,
Is there a way to taper a frame?
I’m starting to use Onshape to design model radio controlled aircraft and I’d like to use frames for wing spars and fuselage longerons but I need to be able to taper them.
If it’s not possible I’ll revert to using lofts.
Thank you.
Thank you.
GregBrown
Member, Onshape Employees, csevp, pcbaevp Posts: 340
Update: I just revisited an old wing (RC glider) and used this technique on the upper and lower spars. Seems it is possible, but not sure I'd like to build it this way from balsa
https://cad.onshape.com/documents/a9f9f141240a2eaff8534193/w/e35e6dd85a7c672542e52b83/e/e304b1d8fd6e2103b00fe47b?explodedView=Mt3R9w+7Gl8aerPN7&renderMode=0&tangentEdgeStyle=1&leftPanel=false&uiState=6691d0e461ea570a9fc45449
