Taper frames
graham_lockgraham_lock Member Posts: 249 PRO
Hi,
Is there a way to taper a frame?
I’m starting to use Onshape to design model radio controlled aircraft and I’d like to use frames for wing spars and fuselage longerons but I need to be able to taper them.
If it’s not possible I’ll revert to using lofts.
Thank you.
