Tab won't bend
alan_curleyalan_curley Member Posts: 7
I have a project using sheet metal and I'm trying to see where bends will align with Tabs on the part.
https://cad.onshape.com/documents/4ed0b1f7dd61d9064b56729b/w/82b5013a09cf6bbd88a7875e/e/b6c22f8f2cfd97758c511348
When I follow the instructions, it won't highlight the tabs as a part to bend, regardless of where I place the bend line and what i select as the face, it just bends the whole part.
Has anyone any suggestions?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,583 PRO
    The "default" doesn't work but it works if you pick "hold line" for the bend alignment. It also works if you decrease the bend radius a lot (which you probably want to do anyway as it doesn't look great):
  • alan_curleyalan_curley Member Posts: 7
    Excellent, that worked, Thank you
