SimSolid Users
shawn_crocker
Member, OS Professional Posts: 914 PRO
in Simulation
Anyone out there using simSolid? We are currently evaluating it. After a few days of use, this seems like an incredibly powerful tool. The power I think it stemming directly from how fast it solves a study. I am solving things in 10-20 seconds that would be 30mins-1 hour in other systems I have tried. What I am curious of hearing about is if simSolid's whole "meshless" solver is truly accurate? Of course, anything I have seen is either claiming perfection or claiming absolute fail but I would love to hear if people are actually using it and finding the possible trade off in accuracy for speed noticeable.
With any simulation, you'll ultimately need to validate it with real world testing. Do you have other test results you can try to duplicate?
I have used SimSolid in the past, and it is great if you have a lot of parts in a big assembly!
The last time I used SimSolid was a few years ago, so some settings might have changed since then.
I made it a habit to import the geometry with a "fine" resolution. This helped to get the correct curvature into SimSolid and improved the stress accuracy.
There is also the possibility to apply local solution settings for groups of parts.I also activated "adapt to thin features" and "adapt to features". You can also refine the stresses display in the results view.
I have been getting results very similar to other mesh based systems by tweaking those settings as well.
